the problem with the stock one is that its not adjustable (to adjust the fuel pressure of course).minivan_don wrote:if your upgrading the injectors (550-660's) and pump (walbro 255), is the stock fpr not sufficient??
That is exactly what I was trying to explain.Sil240 wrote:Ummm. I dont really think it matters if you upgrade to 550's or 750's.You FPR doesn't care.It's job is to hold pressure up until (X pressure) then after that bleed it off.The only thing would be if you have a Crazy big fuel pump that putting out a lot of pressure and it either can't hold the pressure or it can't bleed the fuel off fast enough.
stick with the stock rail and stock fpr, especially for 550s..ecr33noob wrote:I have a r33 gts25t with the RB25DET and I was looking to get one that could handle a aftermarket fuel system and can someone tell me why some need to have adapters to install the FPR because I thought it just replaces the OEM part...thanks
P.S. I was planning to get the HKS one but it needs an adapter and I was told that the NISMO one could not be used on an aftermarket system...I am getting the Greddy manifold with HKS fuel rail and 550cc injectors
