gingerbredman wrote:However, I'm 95% sure that a 12:1 would add more fuel, hence 12psi of fuel pressure to every pound of boost, correct? and so forth..
Yes.
gingerbredman wrote:So, would using an 8:1 fmu on a mid-boost setup be the utmost limit? I was planning on using a 10:1 but since everyone seems to like the 8 I figure I should do what works. Now, I'm going to run an atmospheric bov (stuf lol) because as long as it's taken me to simply get a turbo for my project I don't want to risk losing it to flutter, even if it means it won't retain stock driveability. I could afford the extra gas I'd spend, but if I had to break down and buy a frickin turbo I'd be screwed..It'd be temporary until I upgrade injectors and get a good ecu tune. So the point of all this blabber is "Will running an atmosheric bov with and fmu alter the ratio of the disk I'd need?"
Running much over 8 psi on available fuel pumps probably won't do any good. As flow increases, it becomes more difficult to keep the pressure up. At some point, regardless of what FMU ratio you run, the fuel pressure will stop increasing. At this limitation (which will vary with pump size and perhaps condition of the pump), fuel flow will be the same, but the differences seen will be how quickly the system reaches this limit. Higher FMU ratios will run richer sooner but will ultimately lean out as it reaches max flow.
The only real fix is to build a higher pressure system that can keep up with the flow as well. Doing so would likely require a expensive pump with custom work to fit the pump in the tank correctly and possibly increased fuel line sizes. Not to mention as pressures increase you'll be heavily taxing lines and connections. I'm also not sure if too much pressure might affect injector operation either.
gingerbredman wrote:Also, I heard one guy mention that using an in-line fuel pump along with the fmu is really good, any word on this? I mean with the hi-pressure in tank fp as well, of course.
An i-tank will be more than adequate for this type of boost. Beyond this, its likely, going with a set of larger injectors along with a piggy-back to control them will not be much more.
gingerbredman wrote:You guys are probably gonna tear at me like old people on applesauce but I'm trying to bum my buddy's 370cc's for my project, problem is he won't do anything with his sr.. even after getting smoked by a lifted Caprice...
Not sure what a set of SR injectors are going for these days, but they were pretty cheap when I got a set years ago. But you'll still need a piggy-back, a tuned ECU, or a stand-alone to compensate for the larger injectors...
