Which flywheel to get?
Dryftyn850
Which is the best flywheel to get out there.
eddiec
Car: 91 S13
the stock one works pretty good. if you just want to spend some money then the fidanza is what i have. its just about the the best option out there. this link has pics of mine http://www.cardomain.com/memberpage/395215/6
Gorath
It is a custom one that bolts up and lets you use a 280z or 300zx 240mm clutch instead of the stock 225mmIt wieghs around 11lbs and the clutch surface is can be replace for i think $80. It was holding up well on a guys 240 with a T66 and 530hp
Kaizen
Car: '92 Nissan 240SX Coupe
I don't like aluminum flywheels so I got a chromoly Jun for a KA if that's what you got.
