Which engine is this?
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
musashin
Car: 1993 S13 hatch
So I'm planning on buying this 260Z, thing is an amazing deal. The previous owner died in September, and the car is now being sold by his brother. He says his brother was adamant that the engine was from a 280Z. I thought it was interesting that the valve cover says Nissan and not Datsun... I really have no way of knowing, so I figured I'd ask the experts. So which engine is it?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
all the cam covers say missan with few exceptionslook the base fo the engine below and forward of the drivers side engine mount, it has a casting code, E30 = 240Z, N42 = 280Z, F54= 280ZX
you can also looks at the base fo the cylinder head below and beside the #2 spark plug, E31=240Z, E88 = 240Z, N42= 280Z, N47=280Z, P79=280ZX, P90=280ZX Turbo
those carbs are 4 screw round tops, found on 71 240Z's, the header is of course aftermarket
Pharaohabq
Car: 92' Nissan 300ZX NA
it's also got ZX wheels, and the Nissan on the valve cover both lead me to believe it's got a ZX engine in it, likely a 79-81. Only the casting #'s will tell you for sure tho. Z looks like it's in decent shape..
Oh Brake fluid looks low, caution driving like that...
musashin
Car: 1993 S13 hatch
On the brake fluid being low front, the seller says the e-brake isn't working right now. Could low brake fluid be causing that?
evildky
06 Nissan 350Z GT
no, the brake fluid has nothgin to do with the e brake, most likely a siezed cable or lever
Return to “Datsun Z Forum”
