which ecu pinout number is for the wire from the greddy turbo timer?
sr_powered
Car: 1990 Nissan 240sx SE
i just got a greddy turbo timer, hooked it up already, but i need the ecu pinout number so i can connect one of the two wire (purple and brown). i know one of the wires is for the O2 sensor. thanks!
da40
Car: 1995 SE 240sx
read some forums i know its in here somewhere bro
sr_powered
ive searched, but no results. come on, somebody has to know. im not the only one running a sr20det. i tried searching for a long time, but nothing mentioned about the wires to the ecu.
SpeedRacer1
Car: 1990 240SX, G35
sr_powered
okay, a little more thorough to my question: which ecu pinout number or wire should i connect the wires from the greddy turbo timer to?
SpeedRacer1
Brown is for the parking brake, wire it straight to the parking brake connector. The purple is for the speedo NOT the O2 signal. The speedo signal is what you want to tap at pin 32, yellow wire with green stripe if you have an S13.
sr_powered
greddy's japanese manual had an o2 sensor being connected, so i thought one wire goes to o2 sensor. but thanks bro for the info! appreciated
