Which drop is best?
fuzion
Car: Cars.. Web/graphic design.. Yuppp
Ok, I asked a while back but never got a definite answer..
If you use the Eibach prokit (1.8 up front 1.2 rear drop) with KYB GR-2s they WILL blow out, right?
What if you use Eibach pros + KYB-AGXs? Will those blow out at all?
I saw someone say Tein STechs + Tokico blues will work.. which of these is the best way to go??
I want it to be lowered, perform well but not hop 2 feet off the ground when I go over a bump..
chmercer
prokit and agx, about a million people run that with no problems.
mouse
Car: CARS CARS
The AGX are adjustable and I just installed them in my buddies civic with some coilovers, and they perform like champs even when the car is lowered all the way. If im correct i think the pro-kit drops a lot less than the sportlines, so I dont see why the GR2s would fail but if the majority think so then that sucks. I would go with AGX if i hadn't decided on the TEIN dampers, Just my .02. :)
fuzion
Thx guys :)
Sportlines are like 2" drop.. prokits are 1.8"/f and 1.2"/r
GR-2s are not supposed to be lowered.. I'll go with AGXs :)
mouse
Car: CARS CARS
np good luck
veilside180sx
i had gr2's on my b13 w/Progress Springs that lowered it 1.7 f/r. It rode fine, very rarely would i actually bottom out, although i figured i would more than i actually did. They have been on there for about 8 months at this point and have had no problems. Seeing as my sis is driving the car now.
