240doc »
https://forums.nicoclub.com/240doc-u6122.html
Sun Jan 18, 2004 6:44 am
I swapped in a 97 engine and used an 89 manual transmission. there are two different length drive shafts that I am aware of so far. The shorter of the two drive shafts came from a 240 with ABS and VLSD. If I am not mistaken, the reason the drive shaft is shorter is because of the speed sensor (ABS) is installed in the front of the Differential housing, thus making it (DIFF) longer and the driveshaft shorter. I had the same problem you are having. The drive shaft support wouldn't line up and it wasn't fully inserted into the transmission. I finally used the NON-ABS driveshaft since my car doesn't have the speed sensor in the differential. Everything worked out fine after that.
