which differentail do I need?
gtune4
Car: toonah
I drive a 90 fastback w/sr, what different options do i have for getting a junkyard differentail?
quiksilvia
Car: 95 s14 se
stock 1990 diff, or the vlsd from the 240, i think the z32 diff can be modded to fit too. im not sure about the jdm ones-180/silvia...
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
you can swap the internals from the 300zx/j30 LSDs, or order a silvia/180sx VLSD that are a dirrect swap. There are some other ones too but im not sure about them.
BuudWeizErr
If you get an LSD with a 5 bolt flange (like most R200V's), you need the axles for an LSD 240.
There are a couple rare instances of an R200V having a 6 bolt axle (which is what the open diff 240 drivers have); I believe the 95 J30 has 6 bolt output shafts.
Mine... I bought it modified. Someone had put 6 bolt output shafts in.
solaris22
Kaaz, Nismo, and Tomei make good LSDs :)
VitaminT
Car: 93 240sx SE
I bought Silvia/180sx VLSD with my clip and it has 6 bolt flanges. Installed with no problems. No rear cover swap and no S14 rubber bushings. Perfect for my S13 hatch.
GodzillaFan
BuudWeizErr wrote:If you get an LSD with a 5 bolt flange (like most R200V's), you need the axles for an LSD 240.
s15 HLSD has 6 bolt output flanges :D
gtune4
Car: toonah
so far the guy said i could get either a j30 z32 or 95 240 lsd? would any of these work?
Gmans13
so godzillafan you are saying the s15 lsd fits an s13 hatch no problem?
BuudWeizErr
Gmans13 wrote:so godzillafan you are saying the s15 lsd fits an s13 hatch no problem?
heh.
Gmans13
LOL...whats that sposta mean bud?
GodzillaFan
the pumpkin goes right in. uses open diff axles. swapping the internals is a little more difficult(but possible)
gtune4
Car: toonah
how do you make the 300zx differentail work, or s14. i want the vlsd, not the open diff.
yellow_jacket
Car: 95 240sx
for the z32: swap the rear covers, get pre95 J30 axles, and do something about the front rubber mounts.
Gmans13
sweet...finally set straight
