!!!which coolant sensor to use !!
richiev8s13
Car: v8 240sx
ok i searched and everyone says differnt thing dont know which on to belive i have a 1996 240 with s13 blacktop sr
which year is the right one
whICH coolant sensors should i buy that will work
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Hijacker
Car: '92 240sx Convertible
'94 F-150
I know I wrote this in the FAQ (handily linked in the top of the forum), but I'll re-type it. For the gauge cluster sensor, ALWAYS buy the one that matches your chassis, in this case you want one for an S14. It will screw into the S13 motor, don't worry. For the ECU sensor (two prong one), buy the one for your motor, so one that would fit an S13 KA. I'm 99.9% certain that the ECU sensor didn't change on the KAs going from the S13 to the S14, but it's better safe than sorry.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
^^ Exactly always buy the one that matches your chassis.
