amc49 »
https://forums.nicoclub.com/amc49-u275146.html
Tue Nov 14, 2017 8:09 pm
Different gauges need different sets, they commonly do not use the same fixture on the gauge unless it is a more expensive Milton type quik coupler. I've got like 3 testers and none of the fittings for each fit the other gauges. The Milton type because of the break across it tends to leak and then your numbers are spit only.
What you are trying to say is that you need adaptors to fit YOUR specific gauge. There really is no industry standard there. If the end of gauge ends in a tire valve stem size you may need that one, I forget the exact size but it's on the net.
