Taylor008 »
https://forums.nicoclub.com/taylor008-u89512.html
Fri Jul 25, 2008 12:12 am
Let's say this first. The higher compression, the bigger the boom. Same way with bombs, if you just light a bit of gunpowder you will see a little sparking, if you compress it and seal it, you will get an explosion. Tighter you pack it, the bigger the boom.
Higher compression is just that. Higher compression. If your running +-20lbs of boost and higher compressrion you will need forged rods and 95+ octane with that set-up. I'm not sure if you can make 400 on less than 20. Unless you mean 19. Lol.
Think about it. Your pushing 19psi into a enclosed area, say a metal box, 5"x5"x5" Which would represent 8:5:1. Then your pushing the same 19psi into a box 4"x4"x4". Which would represent 9:0:1. As you can imagine, the strain on the walls will be greater because of the decreased volume. Now think about this in engine terms. It will be harder on the rods to compress all that into a smaller place, than the stock stroke. Which will in time lead to bent connecting rods and poor compression.
Higher compression engines like the LS1 which is I think 10:1, they don't have to push all that boost in there, so they can have higher compression without sacrificing their engines.
Correct me if I'm wrong.
Hope this helps.
