Dori Dori »
https://forums.nicoclub.com/dori-dori-u2872.html
Fri May 23, 2003 5:41 am
Teins are not notorious for rust. Tein HA's are.
Tein RA's would be a good comparo to Jic FLTA2's. They also have an inverted front sturt (which is nothing really 'trick'...hell, some new factory cars come with them on all 4's), aluminum/ss construction, and the same (45mm) size piston. They are also both mono-tumbe design. Yes, the Teins are more expensive though.
Also, stop comparing coilovers on the basis of spring rates. Every single coilover that people have mentioned can be ordered with any spring rate.
Any of the top coilovers from the big manufacturers will all basically have the same exact specs and perform similarily to each other...so close that 99% of you guys wouldn't be able to tell one from another. Whether you buy Jic FLTA2's, Tein RA's, Zeal B6's, Hipermax's, Cusco Zero2r's, Buddy Club Racing Spec's, Apexi N1's, whatever...they will all perform excelently. Things that should be taken into consideration is whether or not the company has a USA rebuild facility, how long the turn-around time is, how much will it cost, how much do extra springs cost, warranty info, ect.
