Which coilovers are these?
240on430
Car: 1993 240SX SE
...and how do I know what setting I am at? I rotate the valve from the top with a small screwdirver, but it doesn't stop at any point. It clicks, but doesn't have any visualy indicator.
This is what they look like...
gumby74
The colors scream Cusco. They should have a brand painted on the coils somewhere, and the better names usually are stamped on the camber plates. Wish I could help on the dampening adjuster. I definitely think Cusco tho. Ol' skool zero 1's maybe?
koukicody
Car: 93 Mazda Miata
take a close up pic of the label. that might help someone recognize it for you
240on430
Car: 1993 240SX SE
sorry, ya they're cusco's, but which cusco's? old zero 1s?
the zero 1s i've seen on phase2 aren't damping adjustable.
gumby74
They may just be zero 2's. Which cost more than a couple shiny nickels. Is that surface rust or just one hella grimmy set? Try washing around the adjustment knob with a toothbrush. I would hate to think Cusco would sell something for over a grand w/out some kind of set marks. Then again, stranger things have happened.
Ca_laurier
if they are used...chances are they are an older model that they don't offer anymore. But who cares, if they aren't blown, run them.
**** i have old tanabe sustec pro's (similar to tein basic's) and they kick *** and are stiff as ****
CusCo_S14
Car: 95 240SX se
They look similar to the zero 2 that I have on my s14, can you read anything on the labels? if not you could probably email the guys over at napsusa.com and see if they can recognize them,but I am pretty sure they are an older version of the zero2s that I have
240on430
Car: 1993 240SX SE
CusCo_S14 wrote:They look similar to the zero 2 that I have on my s14, can you read anything on the labels? if not you could probably email the guys over at napsusa.com and see if they can recognize them,but I am pretty sure they are an older version of the zero2s that I have
This pic help?
240on430
Car: 1993 240SX SE
anyone know how to find out which setting i'm on?
