I should of done what you did, ASK! Anyway, I was told that my Stage 2, 3 puck, Exedy SUCKS... although it grips like a mofo, it has a very limited life due to the clutch not wanting to slip so when it does slip, it wears much much quicker. So the next clutch I'm gonna get is a ACT heavy duty pressure plate with a organic disk. That holds a good amount so boosting won't be a problem. I plan to get mine from
http://www.phase2motortrend.com. Well, there you go. No puck clutches unless you only track your car... not street.
