which clutch for my ca18det
turbocorolla
Car: cars
hi guys,which clutch and press.plate do you guys recommend me to use on my ca18det?my engine setup:microtech engine managementstock bottom endturbo is a t3/t04E, 63 turbine housing and 50 compr. housinginjectors 680 ccboost will be around 20-23 psii think hp will be around the 300hp, torgue ???????????i prefer a clutch and press.plate from ACT or CLUTCHMASTERS since i have good experience with both those brandswhich stage you guys recommend me from those brands?,and also the part number if possiblecar is my street and strip warrior so i want low peddle pressure not something to press with both feet!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!thanx
boost_boy
Quote »turbo is a t3/t04E, 63 turbine housing and 50 compr. housing[/quote] If you are planning on streeting this thing, look for boost to come in at around 4000ish rpm and at 20-23 psi you should be very well close to 400hp with this motor.
turbocorolla
Car: cars
thnx for replying,what ar turbine housing you recommend me??maybe .48??will the stock bottom end support the 20-23 psi abuse??any more suggestions on which clutch to use?
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
the bottom end should be able to withstand the abuse, and i do believe that you will have to swap out the bell housing on the transmission to use a clutch by one of those companies. spec makes clutches for the ca, id try them out.
mattlord42
Car: 1991 240SX Coupe
Actually if you get creative with a dremel you can use a KA24DE clutch from ACT. That is the clutch that we used in the CA swap that we did.
Matt
Trigger
will the clutch from a KA24E work? I dont know but i am going to see I get my motor in today and got a cluch chillin from my KA.. I am going to see if it will work
CA19DET
SPEC Stage 3 Kit (good for 350lbs ~ 400whp if broken in properly, and thats what i'll be using) from enjunkuracing.com or spec themselves or any reseller of SPEC clutches..
here is the email i just got from Enjunku Racing
Quote » I would have to say since the stage 3 will hold up to 350 lb/ft torque, you may eventually need a stage 5 which holds up to 500 lb/ft. It all depends on how harsh of a clutch you prefer. Also you can choose between a 6 puck or a 4 puck disk for the stage 3 clutch kit. The stage 3 will run you about $349 and the stage 5 will run about $429.[/quote]
drumma022
Yea, you can take the time to dremel out the KA pressure plate, and overpay for an ACT clutch kit and have it rebalanced to avoid any future damage, OR you can order a SPEC clutch designed for the CA18DET, and will hold much more power.
SPEC Stage 3 is much more streetable than the ACT equivelent and will hold the power.
I have driven many Stage 3 setups and I would have to say nothing comes close to how easy it is to drive.
boost_boy
Ray, what's up man? Holla' at me if and when you get a chance.
Dee
drumma022
Yo DEE, IM me whenever... godzilla240sx. I lost your IM through the new computer move. I remeber it was turbo something.
turbocorolla
Car: cars
hey guys,sorry i forgot,i will be using M&H slicks on the strip(24.5-8-13)now do you guys still recommend me to use the spec stage 3????or go to the stage 4?what is the diff. between them? peddle press?i dont mind if its a little hard to run it on the street,i just dont want any clutch slipping because i used slicks!!!!
drumma022
The stage 3 is sprung, and 4 is unsprung. Even a stage 5 has an insanely light pedal pressure.
turbocorolla
Car: cars
ok,thnx for replyingi think ill go for the stage 4 kiton all our customers car that weve installed an unsprung ACT clutch weve never got any complains so ill take the stage 4!!
