Zion8561 »
https://forums.nicoclub.com/zion8561-u28751.html
Tue Jun 19, 2007 1:37 pm
Found the answer to my question and I am posting for anyone who searches later...
Just got word from ACT that you need to use the clutch kit based on the year of the transmission you will be using because the throw out bearings are different. See email below with ACT part #'s.
"Jon,I got your application mixed up. Since you are still using the 92' transmission you would need to use the application for that transmission which are the NX4-HDSS or NX4-XTSS kits. Both are ideal for street/race applications and the HD will hold up to 267 ft/lbs of torque and the XT will hold up to 333 ft/lbs of torque. Both kits come complete with the pressure plate, performance organic disc, release and pilot bearings, as well as the alignment tool.Regards,Richard BarzaghiCustomer Service/Sponsorships"
EDIT: Just got word from AMS also
"The difference is in the step on the flywheel. I am not sure which one hasthe step and which one does not. I would order according to the year of yourflywheel.
ThanksChris"
Modified by Zion8561 at 5:48 PM 6/19/2007
