which carb to go with
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
Steveka24det
Car: 240sx 91
http://www.webercarbsdirect.com/category_s/419.htm
theres the link from who i was going to order from, which do you think is the best
i was thinking about ordering the " 36 Syncro" for $280
i have money to play with but i dont want to go bigger unless i can find a side draft kit .. does anyone know if exist for this truck , i have a 1985 z24 2wd truck
thank will look at replies before the end of sunday night to order my carb, and again sorry for all the questions :confused:
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
I forgot what size I got but the weber is freaking so easy to mess with. I like it. If you need more fuel just increase the jetting.
noface
Car: 1985 Nissan 720 4x4 King Cab
they'll all work...
depends on what you're after... fuel economy and driveability or performance.
So if the plan is to build a hotter motor, cams, headers, more compression, etc, the 36 syncro would be better.
If you just want a great running truck that gets good gas mileage, and performs better than the stocker, get the 32/36.
I ran the 32/36 on my truck when I had the Z24 in it, and I was a real happy camper.
The 34mm Weber will be somewhere inbetween the two, so it might be a better option for you, but don't expect the mpg you'd get with the 32/36.
IMO, the performance between the 32/36 and the 34mm is negligible, at best, so if it were me, I'd have the 32...
Only reason I don't have the 32/36 and the Z24 is that the engine liked to blow head gaskets, and I was tired of swapping them, and the cost to rebuild was the same as to add a later model KA with fuel injection...
Return to “Datsun 720”
