Which car has bigger turbos?
Nissan 350z / Nissan 370z general community discussion forum
Nismo300zx
Car: 1990 300zx Twin Turbo
What size is on the VR4/Stealth TT, and are they bigger than the Turbo Z's???
aris_unlimited
Car: 1998 Ford F150 4.6L 5 speed. Edge programmer, 2" lift, 35" tires.
I would suggest moving this to general chat and out of the 350z section. You'd get more traffic of people that might have a better chance of knowing rather than trying to get the info from a section of the forum that is dedicated to a single type of car........and it's not either of those.
zvr4
Car: 350Z/3000gt VR-4/Evo IX
Nismo300zx wrote:What size is on the VR4/Stealth TT, and are they bigger than the Turbo Z's???
The VR-4's stock turbos are TD04 9bs which I believe are slightly smaller than the 300zx. I know the stock Z turbos are capable of a couple more psi than the 3000gt. The housing is about the same size though.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the Z32 turbo's are a garret T25 each flowitn only around 20 lbs/min, I have no idea what the size or flow rate of the mistu turbo's are
the stock Z32 turbo's properly tuned maxout around 400 whp
and of course the Z33 did not come with turbo's
C-Kwik
As far as I can tell, the 3000GT used Mitsubishi TD04-09B turbos. Not sure how it compares to a T25, but a T3 can support more than 100 CFM at 14.7 psi.
evildky
06 Nissan 350Z GT
I've never seen a turbo rated cfm at any given psi, that would indicated speed over time at a given pressure, as the pressure changes so would the flow rate due to the increased density of the air, most turbo's are rated in lb's/min which indicated a volume over time my T3O4e is rated at 53 lbs/min, I don't think I've seen any T3 architecture turbo exceed 80 lbs/min, whihc would be enough to make around 800 hp and that really maxes out the amount of air the T3 fram can haldle, honesly if you are going over 600 hp you should considder a t4 frame
C-Kwik
I've seen compressor maps using both. I agree the CFM rating leaves a variable, but I think its based on sea level ambient pressure. I went off what I found on some sight about the 3000GT. And unfortunately, their maps listed the flow rates in CFM.
evildky
06 Nissan 350Z GT
I found some maps but they are rated in kg/sec
looks like it flows a bit over .13 kg/sec, so if someone eels liek doing some math
Viggy75
Car: 2008 Nissan 350z
damn i learn somethin new every day
Return to “350z / 370z Discussion”
