Which car do these wheels look better on...
texas_s13
Car: 90 240sx hatch and a 92 coupe
Do you think these wheels look better on my coupe or my hatch....
texas_s13
this is my coupe with the same wheels
nismofly
Car: 89 Nissan 240SX Hatch
probably on the coupe i would say
accel junky
Both.
nismofly
haha ya, get another set
the reason i said the coupe actually is i think they look real good with that color
texas_s13
nismofly wrote:haha ya, get another set
I know in need another set but i drive the coupe all the time.... I got the wheels when i only had the hatch..
nismofly
then if you drive it more, imo they look better, id put them on the coupe
240DRFT
i think there better on the coupe...but you need to lower both
Red coupe
Car: 92 Nissan 240sx Coupe
hatch....but I like rims that dont stand out much, and I think they look more natural on the hatch for some reason, I might not notice them on that hatch picture right off but they stand out on the coupe, but that could just be in the angle
on second though it deffinatly is the angle the first pic doesnt show the rivet things ore the imprint on the spokes...put them on what ever car is used more
BuudWeizErr
either/or, as soon as you get spacers and lower it. until then. stock wheels fo life.
Altiman94
Car: 1989 Nissan 240SX
Is that an aftermarket sunroof?
nismofly
on the coupe i mean youre talking about...coupes got optional factory power sunroofs, our hatches didnt
ralphdig
Car: S13 240SX SE - FiatSchumacher- Peugeot 307XR- Renault Alpine A110
That nasty pic is out of place here!
nisYHralli
ralphdig wrote:That nasty pic is out of place here!
say hi to Goatse
574-240sx
Car: Nissans, Toyotas, Subaru
Need spacers for those 40 offset rims. Also at the least a set of springs will help. I like them on the coupe.
BuudWeizErr
which url to nico are you using? I must have missed one when I was adding sites to my allow list.
texas_s13
574-240sx wrote:Need spacers for those 40 offset rims. Also at the least a set of springs will help. I like them on the coupe.
What kind of spacers do i need, and will i need longer wheel studs...
BuudWeizErr
texas_s13 wrote:What kind of spacers do i need, and will i need longer wheel studs...
no, you need bolt on spacers. you couldn't get studs long enough to fit the size spacer you need. I'd go 30mm BOLT ON spacer. it bolts on to your stock studs and gives you new lugs to bolt the wheel on to.
http://www.wheelspacer.com
texas_s13
will i need spacers for the rear to.
BuudWeizErr
texas_s13 wrote:will i need spacers for the rear to.
yes
texas_s13
ok thanks
crzycav86
Car: 93 Nissan 240SX KAT
You don't have to get spacers unless you want to be ultra-jdm-driftR-tyt3 like ChunkiDori.
Unless you're really concerned with aesthetics, you'll only need those spacers to clear big brakes or to increase the distance between the wheels, if that's what you're into. Just don't feel like you absolutely NEED spacers.
