Which brake set to get for G37xS coupe (Akebono BBK)?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
tm2016
Car: 2012 G37X Sport Coupe (Akebono BBK)
Hi all,
I reached here after exhausting my research capabilities.
I have a 2012 G37X Coupe with the Sport package. This means it has the Akebono BBK on it.
I cannot, for the life of me, get a straight answer regarding the name of the pads used from the dealerships I have been calling around.
I finally got someone to give me the following part numbers using my VIN:
d1060jl00j (front)
d4060jl00j (rear)
No one can confirm if these are Akebono pads. All I get from them is "Infiniti pads".
The I decided to look for brakes myself; found that StopTech Street Perf is held in high regard on this forum, but I am confused about the right size. I found three sizes as follows:
1. StopTech 309.130460 (Front)
2. StopTech 309.130470 (Rear)
and to make things confusing
3. StopTech 309.09050 (Rear)
So, here are my specific questions.
a) Do dealers use Akebono pads, and are the part numbers listed above the right OEM pad for the Akebono BBK?
b) Should I buy my own StopTech pads and if I were to do that, which of the above listed is the proper rear brake-pad set?
c) Also, if someone knows a good Brake shop in Massachusetts which would gouge me for prices, please let me know?
Kindly help me out.
Regards
audtatious
Reach out to Mike at Tunerzstore.com and he can get you some alternatives to the OEM parts. It's so easy to change pads on the sport brakes you should save the $$ and do it yourself.
Here's my how-to: http://infinitig37.com/g37-change-brake-pads.html
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
We have plenty of pads to choose from to include OEM maintenance advantage pads, that are cheaper than the standard OEM and also include the shims, which the standard OEM pad doesn't. The OEM part#'s you have listed are the correct pads for Sport package brakes. Who knows what brand name Nissan uses for their branded "OEM" pads, they come in a Nissan Box with no other markings. All we know is that AKEBONO makes the brake calipers, period.
G37 Brake Pads
That is the link to the brake components we offer for the G37. If it doesn't say (AKEBONO) in the title, then it doesn't fit the sport brakes. The description of each item also includes vehicle fitment.
In short we offer the following Pads, all listed on the website:
Hawk HPS
Hawk Ceramic
Project MU
Centri Posi Quiet
Stoptech Performance
OEM
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
