lino wrote:Will the double din 6 CD in dash work? Do they play burnt CDs?Will a Bose unit from another make car work?Will a non-Bose Head unit work without changing wires, amps etc...?
As I recall a Nis/Inf that is "standard rectangular double DIN will fit and work. IIRC, someone has done this, but the in dash 6 disc got for >$300 and the singles can be snagged off ebay for ~$125.
If the Nis/Inf Bose has the DNR button ont he lower right hand corner it should plug right in, if not it will need the adapter. It seems 90 and early 91's used different amps and may not accept the swapped unit as easily.
Any non-bose will work with the correct aftermarket harness or self wiring, I'm pretty sure someone posted the "what wires go where" how to at some point.
