compression »
https://forums.nicoclub.com/compression-u9345.html
Wed Aug 25, 2004 10:42 am
The AEM has a built in boost control function that works awesome. Mine is steady as hell, never spikes, never goes over the pre-set limit.Does the stock SR have an electronic solenoid that controls boost? something normally operated by the ECU?If so, then yes the AEM EMS will use that, otherwise you will need to buy a solenoid. A good one to use (that AEM recommends too) is one from a GMC Cyclone.THey are onyl about $30 and work great. thats what I am running, along with a TIAL 35mm wastegate.Contact AEM for a release date, or look on their EMS forum. You do not have to register to read the posts.
