which battery is better for my sr ???
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
Ok,Im installing my Hybrid front mount intercooler.And now its time to buy a small dry-cell battery,And iv been doing some reseach and im stuck between the two..The Odyssey PC680 Battery Or the Westco Miata battery.Both are around the same price.I think the Odyssey is smaller so i could have more room.But it might be weaker too.Gimme some input.Im going to order one today or the next..Thanks,
Rosco
Car: 91' SR'ed Hatch
Just an Idea: Get a battery relocation kit from summit racing and then you will be able to get whatever battery you want, without having to worry about "will my miata battery last long?". I'm either going with Optima red or yellow....Gel Cells definately are better than dry cells.
teddy
Car: Saab Turbo and MR2
That's what I did. Bought a Taylor battery wire kit for relocating it to the back, got an Optima redtop for a realllllllly good deal online, and it works great. Frees up some space in the engine bay too which is nice.
corey240
Car: 1993 Nissan 240SX Base Drift Machine
i relocated my optima redtop to my trunk
wildacexxx
Car: 2002 Q45 nav sport
corey wat kit are you using?
9240sx
I want to keep the battery under the hood..
corey240
im not using a kit lol (not being rude) i just wanted to get the crap done so i finaly scraped the money together and went to advanced auto and got 23 feet of like 3-4 gauge cable, an optima redtop 720 cca battery,and a marine battery box(works just fine) and done! it cost 176$ all together. here a pic of the supplies i used.
corey240
as for you my friend if you want to keep the battery under your hood then well you gona need to shell out the money to get a small sealed battery not a miata battery. svr,optima has them and a few other ppl. i have one i just took outa my car il sell it to you for $100. the thing is that if you live somwhere, where its gona be cold out either alot, or it gets really cold somtimes your gona have problems with a small battery nomater who its from. beleive me i know my battery was full charged and it got 25 degrees out and the next day it was dead! so if i was you id just get the swap to the trunk. plus if you buy an optima it comes with a 3 year replacment warrenty so you can do what im doing and take it back and couple years for a new one
Neil
Car: shooting laser guns
PDM-Racing.com is selling a slim battery from a company called Genesis for $86 + shipping right now, you also have to buy their battery terminals for another $16.
http://www.pdm-racing.com/products/power.html scroll 3/4 down
Also DGTrials' Festive Garage is selling a slim battery but for $167 but I dont know if it's a better brand or what.
http://www.festivegarage.com/p...id=92
S13240
My brother and I both use Westco with no issues. Anyway, the issue of relocating the battery to the trunk is if you go out to the street legal drags you need to make sure you have an external kill switch that works or else you're not going to be dragging.
dustyk
I use a PC680 battery and would recommend it unless you have some giant audio system. I havent had any problems draining the battery and I think the PC680 is the cheapest dry cell battery you can buy. I think I got mine for under 80 shipped off of a seller on ebay that just sells odyssey batterys
9240sx
I just have a cd player and 3 gauge's extra to power..Do you think the PC680 will have enough power for my car..???
mallbor240SR
Car: 240sx 1990
im using the SVR batterry that heavy throttle sells, works really good and i think it has a higher CCA than the optima battery
jt15833
Car: 95' 240SX
pc680 will be fine, gauges dont draw that much amperage
9240sx
I just odered the pc680MJ..with the Auto terminals..Only cost me around $90 shipped...Not be bad....Thanks for all the input guys.!!
srdrps13
Car: s13
corey.. is that box mounted? lol i haven't mounted my kit from summit... not too sure which way im going to do it
boost_creep
Car: 92 sr powered coupe,06 Spec V
corey240 wrote:as for you my friend if you want to keep the battery under your hood then well you gona need to shell out the money to get a small sealed battery not a miata battery. svr,optima has them and a few other ppl. i have one i just took outa my car il sell it to you for $100. the thing is that if you live somwhere, where its gona be cold out either alot, or it gets really cold somtimes your gona have problems with a small battery nomater who its from. beleive me i know my battery was full charged and it got 25 degrees out and the next day it was dead! so if i was you id just get the swap to the trunk. plus if you buy an optima it comes with a 3 year replacment warrenty so you can do what im doing and take it back and couple years for a new one
you shouldnt have a problem at all with a slim battery dying in cold weather.my car sat for 6 months.i started it once a month.i have a optima yellow top slim batt up front.that battery never even should any signs of a weak start.
