Zee wrote:That is not completely true and whoever you have do your body work is screwing you for a $1000 plus. That dent doesn't look like it goes all the way to the door jam, could be just me.
Anyway, I cannot really answer this question the best only because if you have the money laying around than go for it. Otherwise, unless it bothers you if is not really affecting you in anyway, so wait until you have the rest of the body work done with it.
I suppose if you wanted to use half a tub of bondo after you pull that sucker. It goes right up to the seam, its never going to line up close to correctly, and pulling it could split the edge. The thousand plus was assuming they have to get a quarter panel. Sorry but I consider pulling a dent that big and filling it with bondo sloppy work. I'd rather not have my car's side burst into flames when a spark from someone's cigarette hits it.
My hyperbole aside, $100 is too good to be true and a guarantee of sloppy work you'll regret. Wait and do it right or don't do it at all.
