elwesso wrote:first off i checked the belt lengths in the parts book, and theyre the same 90-96...
Are you going to be recharging with R12 or R134...?
I'll be using R134. I already have a new drier sitting in the box and plan to get a full system flush before recharge. I seem to remember mentions of the 94 compressor using a larger belt from those who have tried in early G50. I compared pulleys side by side and the 94 was definately of a larger circumference. Hmmm? Well, no matter, I don't have the 94 so my choices are used remanned with probably lower mileage or used OEM.
BTW Wes, thanks for your help that day. I did manage to pull off a 94 driveshaft which I will install soon. The centerline bearing is a much more robust unit as it has two rubbers surrounds versus 1 on 90-93. Also, the 94's rubber was still supple! I measured them side by side and they should work as they seemed the be the same length. The 94 is at the bottom in the pic below.
Modified by DrewQ45 at 11:13 AM 8/21/2006
