Who told you that info? Mine are hub centric all around. Ichiba also has a 1 year warranty. I've had mine for close to 2 years with no problems.naed240sx wrote:Go OEM all the way around.
I hate ichiba front hubs because they are machined incorrectly. Ichiba fronts are not hubcentric for Z32 rotors. This means you have to rely on them centering on the studs, which is not a good idea. EVERY set of Ichiba front hubs has this problem, although I have not heard too many people mention it.
I'm sure that they are hubcentric for the wheels no problem. for the brake rotors, the hubcentric portion simply isn't long enough. Not many people even realize that their are two separate diameters. Your rotors are being centered on the lugs. Nobody told me this information, I learned it myself because I owned Ichiba hubs for awhile, and also every set I have ever seen has the same problem. Check out this picture from their webpage and compare it to the s14 front hubs. The s14 hubs CLEARLY have different machining for the hubcentric part.usdm_180sx wrote:
Because you're saying that the aren't hub centric. I would just like to see how they fit because mine were fine. I do recall that there was a bad batch but iirc it was fixed.naed240sx wrote:Why? With rotor on you wouldn't be able to see much...Although I guess I could have shown how the rotor would rest on the lugs instead of the hub.
FYI the same problem occurred with 3 different brands of rotors, including the Brembos... so it's not a rotor problem, its a hub problem. I chose the brembos because they have the smallest lug holes allowing them to center satisfactorily. I am now using the brembos on my new s14 hubs and they center far better, because they are centered on the hub, not the lugs.
I've seen dozens and dozens of build threads with ichibas, and they all had the same problem. Never seen a single one in person or in pictures that was correct. Must have been a LARGE bad batch.usdm_180sx wrote:
Exactly. Thats what I said earlier. That part is like twice as long on any OEM hubs.94_240sx wrote:They should have made this part bigger, so rotor can fit better.
It didn't actually cause me any problems. I was very worried about it at first, but eventually I was making 100 to 10mph stops on that pictured setup all day long no problems. No vibrations.94_240sx wrote:Usually, rotor fits very tight on the hub and most of the time, you have to use bolt holes on the rotor to separate it from the hub. First, I thought it was hard to remove because of rust, but that wasn't a main reason. Yeah, I can see that there's a small gap there. It's small, but it could cause a trouble when you drive in high speed. That's why hub centric is really important.
does that go for just z32 rotors, or same goes for the s14 rotors?naed240sx wrote:Ichiba fronts are not hubcentric for Z32 rotors..
It depends on how large the bevel is on the backside of the part of the rotor that goes around the hub. Since I've never looked at the backside of an s14 rotor, I cannot say.240sxHitman wrote:
I don't know how much more flushness you're looking for because iirc oem rotors fit the same way.naed240sx wrote:
Notice how there is no gap between the top of the lug holes and the lugs, but there IS gap below the lugs to the bottom of the lug holes?
The rotor is resting on the tops of the lugs, not on the hub as it SHOULD. But as I said before, the lug holes are small enough on brembos that it works.
