Oh, I remember now.
You had the Q with several bad overheats.(Or your wife did, by driving it while over heating w/ super low coolant)
You dont need to go to the dealer to have compression checked.A good independent you trust can check the engine as wella dn a compression check is just one part of that.Tell them you know of more than one severe overheat and to check this aluminum engine to see if its still good.
It would be best to tow, but certainly a few blocks are possible with no overheating, even if the waterpump is totally out.
(Beware bad stories exist from PPL trying to save on the tow and destroying a perfectly good engine that way, when their waterpump was toast, one of T3's customers had an overheat and then turned around driving the overheating engine back over a couple dozen miles completely destroying the engine).
If it was my own car, I would either tow (remember NEVER with the rear wheels on the ground) or drive less than a couple of miles.
Bring it to a shop you trust and then let them tell u if engine is gone or not. if it is, buy a known good used engine.(If therer are no independents around you really trust, use the dealer)If it is ok, everything checks out good, you will probably have to replace knock sensors which crack under overheats, as well as the pump.
Fred...
PS: How are things going with the wife?
