Universal_Remonster wrote:I've also heard that it causes the engine to use more fuel which is good since with an aftermarket intake/filter it's using more air so it evens out the ratio.
But yeah, I think I found it, just kinda off the throttle body thingy.
With an aftermarket intake, your car will use a little more air, but our cars have mass air flow sensors. These sensors will know the car is getting more air, and the ECU will adjust automatically. I don't think your chip will do anything positive.
On a Honda, or some other car with a MAP sensor, a chip might do a little something, since you will run a little lean when you put intake\header\exhaust and the chip can richen it back out.
Also, if I'm not mistaken, your car does not have an intake air sensor, because the mass airflow sensor takes temperature into account, thus eliminating the need for another sensor. I know 91-94 S13's don't have them, but I'm not positive about S14's. As far as I know, the only 240's with an intake air sensor in the airbox are 89-90 S13's.
