wheres the egr valve in a 95 240 showing code 0400
jin3001
Car: 95 &97 240sx
just a few minutes ago i started my car and proceeded to take off as normal but my car said no,it sputtered and then drove off just as the check engine light came on.well i got home and hooked up my scanner and it showed code 0400 egr prob.i cleared the code and drove around a bit no more light.good.im wondering if this is signal is the beginning of the end for my egr valve and if it is wheres it located?any help it greatly appreiciated.thanks in advance.
aaronsnocker1
Car: 93 240sx
Mine is also bad. Just do a simple search for egr valve and prepare to be amazed. I will sort through all of this and post a link to a thread that will answer your question if you are to lazy to do it.
aaronsnocker1
Car: 93 240sx
aaronsnocker1
Car: 93 240sx
aaronsnocker1
Car: 93 240sx
Also here is a link to the 95 fsm http://72.29.75.31/~videof6/ma...5.zip from vancouverbc's sig. That might help in finding the part.
aaronsnocker1
Car: 93 240sx
And here is where you can get a egr block off plate if you want to take it off. http://rigidracing.com/products/KA24_egr.htm
