Where you get your turbo?
Florida240sx
Looking to do a set-up for a friend and don't know where to get a good price on ones. He doesn't want to pay $800 for one. And doesn't want used. Thanx for price/quality knowledge.
myRed240
Car: '95 Nissan 240SX with a KA-T!
'07 Audi A3 2.0T DSG
'11 G37S Sedan
Phoenix turbo has good prices...
r3skyline
Car: nissan 240sx (looking for)
you dont want to cheap out on turbos when your doing a build. also, whats he planning to run? t3/t4, t25/t28. td's? supra turbos? it all depends on what turbo you would like. i have access to many a turbo, run from 400-1k depending on what you want. i also have a hks T51R SPL Turbo that id be willing to sell. but i saved for 2 yrs to get that turbo. heh. was hoping to put it on my ka-t build when i was finished.
DammitBobby
Car: S13 91 KA24DET
mjmturbo.com
I personally have been there several times. They will have what you need in stock. That is all they do strictly turbos and pricing is reasonable.
1995240sxSE
Car: 1991 jeep wrangelr and a 2004 ford taurus
my turbo is from blaastperformance.com. not too expensive. I have 2 turbos from there. Why not buy used?
Florida240sx
POM
hnugen
1995240sxSE wrote:my turbo is from blaastperformance.com. not too expensive. I have 2 turbos from there. Why not buy used?
Do NOT get your turbo from here. The guy that runs that place is a crook. He sent me a 7-bolt Nissan exhaust housing when I specifically told him I needed the 5-bolt Ford. When I received the turbo, I took the compressor off and there were metal shavings stuck on the oil/gunk in the housing, which he denies is no way possible because all the housings they get are completely cleaned. When I sent him the pics, he was like "ohh that's nothing." Then he told me they were out of 5-bolt housings and will have to "repair" a cracked one if I still wanted one. I bit the bullet and kept the turbo. I boosted the motor at 5psi for less than a thousand miles. The exhaust lubrication seal went out and the turbo started smoking. Yes, I did monitor my oil pressure and had the JGS oil restrictor on. But that's not the good part...the damn compressor rubbed up on the housing and chipped a fin off, which sent it into my motor and destroyed it. **** YOU BLAASTPERFORMANCE!!!! I also strongly believe they put Chinese parts in the turbochargers instead of real Garret parts like they claim. I have personally seen two turbos from Phoenix Turbo and they came in a genuine Garrett box with serial number plates. My next turbo will be from there.
S13FX
Car: '69 l20b Dimeski :)
Hit me up on AIM at Pijaczek18 homey, I got all your turbo needs solved plus more.
1995240sxSE
wow I didnt know that about blaastperformance. I must have a good one, or this is why my turbo is smoking and no because of my lack of oil restrictor. I spool mine past10 psi and there is still no shaft play, my turbo is over a year old! Maybe I just got a fluke turbo, or maybe you did?
