Where ya'll buy ur oil/coolant lines for your Upgraded Turbo!
djmace
just wondering where ya'll buy ur oil lines for ur T28 on ur CA's.... I bought some but its pretty much kinda cheap...so where ya'll get urs!
f s t caz
Car: VG30ET D21 Extended Cab Pickup
used stock lines for my GTiR
djmace
i dont want hardlines.....and plus i threw mines away..
Trigger
hardware store
float_6969
I re-used the stockers...
wildacexxx
Car: 2002 Q45 nav sport
u looking for steel braided ones?
NeedCAforS13
Car: CA swapped S13 coupe
why don't you want to use hard lines? not saying you should, just wondering why you're not...
Sean
81na ZX
Car: 81 280ZX, 69 Lotus Europa
Build them yourself. Earl's or Aeroquip (my fav) or Russel. It'll be perfect fitting.
djmace
well ya'll know the size that goes into the block as well as the turbo and coolant...reason why im not using hard lines was because I let my friend re-arrange it so I can use it but it broke =(
BoroBoroS13
Car: S13, RS13, and S14
If you got some cash to throw around you can have taka make you a set. They use all Earls lines and fittings but they also cost like $180 a set. I have em and they are nice but damn thats a lot of $ for some damn lines.
81na ZX
djmace wrote:well ya'll know the size that goes into the block as well as the turbo and coolant...
Take any banjo bolts for the stock lines to a good hardware store and match the threads. You might have to take the Turbo in if it doesn't have any removable fittings. I know most T3s and T4s use NPT (nation pipe thread) fittings, not sure on T28s
float_6969
djmace wrote:well ya'll know the size that goes into the block as well as the turbo and coolant...reason why im not using hard lines was because I let my friend re-arrange it so I can use it but it broke =(
What exactly do you mean by this? The stock lines are bent or you screwed up some threads somewhere?
f s t caz
float_6969 wrote:What exactly do you mean by this? The stock lines are bent or you screwed up some threads somewhere?
i'd bet he tried to bend the lines and snapped atleast one.
