biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Tue Mar 29, 2005 2:31 pm
Set it to 37psi now, runs much better.
at first it could barely idle, since the ECU had learned to try and lean out as much as it can all the time now it was barely injecting any fuel at the correct pressure, once the o2 heated up it idled fine, much smoother
hopefully this will get more than 20mpg now
fyi at idle it was pulling about 29~30 or so psi at IDLE with it set to 37~38 w/ no vacuum connected. which is about right.. see this SXOC post ... I don't know what manual he found the specs in that it specified vac attatched and unattatched, but whatever. I set it ~1 psi too high since setting it to exactly 36.3 is impossible and more is safer
rico: was your 35psi w/ or w/o the vacuum line atttached.. if it was without it was slightly low, if it was with it was ~5psi too high (not beyond the ECU's abilites to correct in closed loop (? i think it is) mode, but will make you run somewhat rich otherwise)
