Where to tap aftermarket oil pressure gauge?
c-rad
Car: 1991 Nissan 240SX w/CA18DET
I was just thinking about this seeing as I am going to order an oil pressure gauge soon. Where does it tap into? I was thinking you could get a tee and tee it off where the oil pressure switch goes, but I am not sure. Where do you guys tap yours?
8ggalant
Car: nissan cefiro
c-rad wrote:I was just thinking about this seeing as I am going to order an oil pressure gauge soon. Where does it tap into? I was thinking you could get a tee and tee it off where the oil pressure switch goes, but I am not sure. Where do you guys tap yours?
if im not mistaken you get a new oil sending unit w/ the gague (i know w/ autometer electric oil press gauges you do) and on my DSM i just used the spot where the stock sending unit came from...im not sure if its the same w/ our current motor...but i figured u bein a dsm guy id throw that in there...maybe its the same
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
i just did away with the stock dummy light and put my auto meter sender in the place of it, granted i should have probably put in an adapter or retapped it but my friend just screwed it in there and made it fit.
it works though and doesnt leak at all. and its not goin to come loose
float_6969
Generally you just T it off of the oil sending unit.
8ggalant
Car: nissan cefiro
so u run two sending units ??
Jezz_s13
Car: Sil80 Track Car
I tee off the stock sender too, http://www.courtesyparts.com sell a Nismo t-piece for $9
http://www.courtesyparts.com/M...3-GTA
c-rad
Jezz_s13 wrote:I tee off the stock sender too, http://www.courtesyparts.com sell a Nismo t-piece for $9
Awesome! Exactly what I was looking for.
Jezz_s13
make sure the thread is right on the bit where you screw the gauge into, apparently (so I've just been told) jap gauges have a slightly different thread to the US (autometer and the like)
c-rad
Jezz_s13 wrote:make sure the thread is right on the bit where you screw the gauge into, apparently (so I've just been told) jap gauges have a slightly different thread to the US (autometer and the like)
I don't like Autometer gauges...I am going to be using Defi gauges. Autometer uses standard NPT fittings... defi and other japanese companies use metric.
DjLiquid
Car: 1988 Nissan Pulsar
where is the oil pressure sending unit located on the block?
c-rad
DjLiquid wrote:where is the oil pressure sending unit located on the block?
Under the oil filter housing, right above the seam for the oil pan.
Not_a_sr
nissan uses BSPT i believe, and autometer is NPT.
float_6969
Well if you're not going to use an autometer gauge, then that special T isn't going to help you, as it's going to be the same threads as the autometer stuff.
8ggalant
Car: nissan cefiro
wish i could afford sum defi's lol
F3600
plug it in the oil pressure sensor.. ive bougth a cheapy mechanical walmart one .. working fine for 3 years. be sure the nylon line is free and not kinked you dont want to snap the line off like myself when racing and RSX ... oil all over the engine bay is not cool
float_6969
did you win, or loose?
