I know this is probably something that has been answered to some degree but I need some help.
A little back ground, I love nissan I've owned three now, and just the other day I bought my first 1991 NA 300zx. Been wanting one since I was a wee lad.
Anyway, here's my issue,
The car starts all the time, every time. It seems to idle at 950 upon start up, then drops down to 500 and sputters and sometimes dies unless I give it gas. However, when I do give it gas, it raises to 1500 and then starts to dip down again (even with me still holding in the gas pedal) unless I feather the clutch and the gas and sometimes it still dies. It wont accelerate past 10mph.
The MAF was recently changed looks brand new.
No Vaccuum leaks as far as I can tell, but haven't formally tested.
I'm assuming the spark plugs are fine because it fires well, however I understand there is a specific type of plug that is universally recommended. I don't know how legitimate that is but, I'm open to possibilities.
The TPS looks just fine, almost new.
The Idle screw may need adjusting but I don't know if that would solve the issue regarding acceleration?
I am going to replace the coolant sensor, because it was corroded, and I know that if the connection is bad, the ECU will make the fuel system too rich in order to falsely cool the combustion chambers. And upon start up on an already cool motor, that sucks. (Still doubt that's the problem but you never know)
I had one friend tell me it could be clogged cats from running too rich.
The fuel filter is brand new,
If i'm not mistaken I think I hear the fuel pump too, Not sure if if being that loud is normal, even if that's what that is.
Sorry for the long newb post, but I appreciate those of you that can help me. I'm hoping it's a simple fix just so it's at least drive-able. I just need to know where to start.
Thanks guys.
