I might be looking into getting one of these but after a bit of research, I heard they tend to crack/have hair line cracks/holes/etc. But, I also ran into the option of reinforcing these manifolds.
Where would you recommend I do some reinforcing welding on the manifold as well as the option of installing/welding some brackets?? Also, do you have any examples with pictures I can see??
Also, I hear there is a problem with thier gaskets not sealing as well and its better off just using the oem set. Correct??
