KenHash »
https://forums.nicoclub.com/kenhash-u94224.html
Mon May 12, 2008 10:04 am
Here in NY we use the E-Z Pass, I believe now used in NJ andMass. Anyway, if you don't have it, it's a square while plastic thingthat you attach on the inside of your windshield, near the rear view mirrorthat gets read automatically when going through a toll booth.
My question is where does one/should one place this thing in a Rogue.This Rigue is the first car I've had with that grayed area (looks like dots)around the glass behind the rear view mirror.
Should I avoid the gray area? CAn the reader even work through it?Otherwise to avoid it, I'd have to put it "below" the mirror from the Driversline of sight, which is low enough to block some visibility.
Any opinions, actual experience, photos, appreciated.
