Where to pick up SS braided water and oil lines for a T25 SR turbo??
JDMbyBlood
Car: 93 240sx Coupe
I picked up SR Blacktop motor minus the exhaust manifold and turbo. There were also no lines. (Water and oil lines that go to the turbo.) I picked up the hard lines, but was told there a real pain in the rear to put on. Not sure how true that is. Anyway, I think I rather use SS lines for everything. Is there a shop/store that sells a oil and water line kit for the SR? I plan on installing a t28 in the future and would be nice if the lines would also fit the T28. Thanks for any info you can provide...
S14-KOUKI-MONSTER
Car: '97.5 Kouki s14 le w/Kouki s14 sr & '03 Xterra w/6" lift on 33s
I got mine from frssport.com. Both the hardlines and ss lines are kind of a pain to install. Not sure whether they fit both t25 &t28, but if they don't, I'm sure that you could just swap the fittings on the end.
JDMbyBlood
Car: 93 240sx Coupe
Thanks for the reply. I'll check them out.....
jubee
Car: 92hs13
i got a a oil line that is i had done i am in no need to for it hit me with a email if intrested. [email protected]
