where to mount seat harness on s13?
otaku64
Car: rps13
where have most of you mounted your safety harness on an s13?
-salvatore
http://www.powerzamcam.com
navysnail
you should use a roll bar, anything more then a 45 degree angle from the holes in the seat increases your risk of spinal compresson in a wreck. attaching them to a strut bar or the back seatbelts is NOT safe
Axel Grungy
Car: 2001 G20 5spd
ive got mine bolted into the stock locations on the sides of the seat, and the rear is secured where the back seatbelt retractor was. i just use this for autox and nothing else, nothing where id have the chance of flipping over (no rollbar)
240marcuSX
Car: E34 525i
E46 M3
^^ word. in auto-x, harnesses arent really for safety anyway, theyre to keep your *** from moving around too much.
themadscientist
I always attach the lapbelt to the front seat lapbelt points and the shoulder straps to the rear seat lapbelt points. I also use belts that distribute the load for the shoulder straps across two mounting points.
