where to jack up my car?
chmercer
i cannot find a good place to jack up my car to save my life. i have been jacking up where the tire jack goes and it is slowly getting more and more bent so i figured i would ask you guys where you are actually supposed to do it. please help, every place i jack up on breaks / bends :P
lok
I would recommend the front crossmember and the diff. for the rear. The front crossmember was recommended to me not to long ago and is an excellent place to jack the front up and put the jack stands under the chassis.
MarvynDT
If you plan on putting jackstands on the framerail, place a 2x6 between the the stand and the frame. Overtime, you start bending/denting the framerail.
sideshow
Car: obsessed with cars.
in the owners manual there are actually 4 knuckles for using the stock emergency jack and those work just fine for me
XCrunner19420
Use the tow hook to jack up the front.
ricebike
2002 Quest
2005 Altima
http://www.nissaninfiniticlub....oints
BadMojo
Car: 2007 Mazdaspeed 3
lok wrote:I would recommend the front crossmember and the diff. for the rear. The front crossmember was recommended to me not to long ago and is an excellent place to jack the front up and put the jack stands under the chassis.
That's what I always do, and I haven't had any problems. Hell, those are the jack points listed in the FSM. The front crossmember is *very* solid and makes a great jack point.
MarvynDT is definitely right about putting a piece of wood between the jack stand and the "frame rail" (not sure what you'd call it on a unibody car). I've seen pictures of those rails that have deformed by just using a jackstand without a bit of wood.
I really wouldn't rely on the emergency jack if you're going to be doing a lot of work on your car.
BTW, use jack stands if you're going to be crawling under the car. Please...
K240
Car: 1993 240sx
a cliff works good some hammers and maybe a couple of bricks should jack it up real nice...
b240
OMG i actually read all of that sig.
RyanT
u mean sideshows? i know what a waste of space lol
Touchdown038
Car: Computers, cars, sports
Still kinda funny how it ends though.
574-240sx
Car: Nissans, Toyotas, Subaru
My car is so low i have to drive on boards. Or I jack it up on the rear end or I start jacking the car up by the tow hooks and go from there. Nick
MasterMan
Car: nothing running at the moment city buses "uck here
#240sx Chat on eFnet!
http://www.mirc.com
TurboKA37
WTF r u talking about masterman? uve posted that on 2 threads ive read so far. oh and i was jacking up my car last night and if u keep the jack points as far forward as possible it shouldnt bend.i kno this doesn have to do with anything but reading about tow hooks reminds me of last night. i was taking off the rear tow hook that is used to tie the car down and the bolts were really rusted so i used a bunch of WD-40 and it help to get 3 of them off but one off them was impossible! finally i got in a nice strong position and started turning the sucker. and i was pulling with all my might(thought my arms would fall off) and after about 20 mins of slowly turning this thing without it getting any easier it came off and i looked at it and i had just twisted the screw to the point where it broke off. this was a big bolt! it was rusted so well in there that it looked like it had been welded in! i couldnt believe it
