ks13 wrote:It T's into your heater core feed under the intake mani. Coolant flows from thermostat area, under mani through that 5/8's pipe, and off that pipe theres a small hose that routes coolant through the cap on the back of the intake mani (keeps PCV valve from freezing in winter) then from there to your turbo water feed hardline on the back of the head.
that make sense?
Greg
Ok, this made sense to me, however i just didnt see the hookup for the part that goes to the coolant line for the turbo. Once i filled everything up with coolant, it started spewing coolant from the part that i needed to hoook it up to, and i found it. It was really really hard to see it though and was hiding from me. Haha.
thanks for everyones help on this one. oh yeah and i drove the car around the block and everything seems fine, but it feels al ittle on the slow side, so im going to check the timing tonight and replace the stock fuel pump with a walbro and that should fix that.
