WHERE TO GROUND MY AMP
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
COLE WORLD
Car: 2011 Nissan Versa Hatchback
IVE SEEN OTHER POST BUT CAN SOMEONE SEND A PIC OR A DETAILED WAY TO GROUND THE THIS AMP BECAUSE ITS SLOWING ME DOWN
Athikerguy4life
Car: 2008 Nissan Versa
If the amp is in the trunk, ground it to the seatbelt anchor. If it is under one of the front seats, you can use the same method.
veronicatheV
Car: 2010 Nissan Versa 1.6
get a self tapping screw sand any spot on the frame get a screw gun impact driver and the ring coupling off your ground wire over the screw and self tap your own ground, supper easy. Just screw to anything that looks like a solid piece of metal under the carpet.
This is my Ground
A closer View
COLE WORLD
THANKS I FOUND A PLACE IN THE TRUNK BEHIND THE TAIL LIGHT
veronicatheV
Great post some pics!
Return to “Versa Technical Discussions”
