where to go next???
fc3sdrifter121
so I have my sr, it has a greddy m spec fmic kit,ssac manifold,xs power dp, test pipe, cat back. greddy oil pan, alum. radiator,apexi intake, and some other small things I am forgetting,I am running 14psi, and from everything I have read , I am pretty much at my max for the t25, injectors, maf, fuel pump, yada yada.I am assuming I should be doing around 250 whp, my goal is to get a reliable 300whp. I am new to sr's, and to be honest I am not that good with forced induction period.where should I go next to reach my goal, I know I need the fuel and some management, with a different turbo.but thats about as much as I know.....
thanks for the guidance
Jesse SR20
Car: 1990 S13 fastback
Upgraded turbo.Larger injectors.Walbro fuel pump.Z32 mafs.Fuel management. Tune.
If it were me, I'd get a GT2871RS. Couple that with the Greddy intake tube kit and the whole turbo is 100% bolt on. If your goal is 300, then 550 injectors are fine. As far as fuel management, I'd go with a rom tune. I'm guessing 18-20 psi is enough to hit 300hp.
fc3sdrifter121
what turbo would be suitable? and what size injectors?reliability is huge for me
CoupedUp
Car: 1993 Coupe
I'd go cheap IMO.
Id get:
S14a or S15 injectors(300 dollars)S15 Turbo(800ish)SAFC Neo(350?)
Total = $1450 Rough Estimate.
Done, 14 PSI = 300WHP.
kickertu
damn there is alot of mis information on this site.
for 300whp, you will need-
s15 turbo, or larger, such as gt2871, gt3071550cc injectorsenthalpy tune. (can be done with s-afc, but no timing controll makes it moer prone to breaking ring lands with any amount of detonation.
bout 17-18psi and you will be there, or real close.
my old setup consisted of an s14 turbo, 550cc injectors, z32 maf, fuel pump, fmic, exhuast, and 17psi, i made 276whp.the s15 is a bigger turbo, but not big enough to make that much more power at lower boost.
if you want reliable and ease. gt2871550ccenthalpy ecumaffuel pump
drive the **** out of it!
spikNspan
Car: 1990 240sx hatch
I'd paint my trunk first, but that's just me.
fc3sdrifter121
it already been painted smart ***
Twinchy
Car: Peg leggin 240sx
Jesse SR20 wrote:Upgraded turbo.Larger injectors.Walbro fuel pump.Z32 mafs.Fuel management. Tune.
Would he have to do any head work to maintain that power or would it be just fine?
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
As long as you obey the 8000 rpm redline no but GReddy EZ Cams (256/256 and works on stock springs) will give you an east 20+hp bump on the cheap.
