ClutchKick »
https://forums.nicoclub.com/clutchkick-u64941.html
Mon May 21, 2007 8:28 am
It all depends on the dealer you go to and what the service consists of...
Every dealer puts together their own "Service" and some add things you dont really need etc...
My 30K service consists of:
Oil & Filter Change, Rotate & Ballance Tires, Batter Service, Replace Engine Air Filter, Replace In-Cabin Micro Filter, Drain & Refill Transmission fluid, Complete Multi-Point Inspection including and not limited to, Fluid Level Check, Exhaust System Inspection, Steering and Gear Linkage Check, Inspect Axles and Suspension, Brake Inspection (measurement), Drive Shaft Boot Inspection, Vacuum Hose inspection, Drive Belt Inspection.
We do this for $459.95 plus tax on parts only... (if you come in and let me know, I can take some $ off the parts...
If you add a Coolant system Flush (which is better then just a drain and fill) it is $99.95 additional...
We do also offer loaner cars as well...
But, not in your area, but possible to make the drive
