1dollar240 »
https://forums.nicoclub.com/1dollar240-u221.html
Mon Nov 18, 2002 10:40 pm
If your rubber seal is in good condition then dont waste money on a new one. The window can be adjusted. Just take off the door panel and look for the bolts that mount the regulator (the track that the window slides up and down on) the bolts have standard nuts on them but have a slotted head in the center- you can fiddle with this untill the window seals well when you close the door. Hope that helps, if thats not clear enough, shoot me an IM: tampabaybrett
