White Comet wrote:well i'm not speaking of this particular set up since i cant exactly picture what you're talking about. but in general, i've used home depot fittings and hose clamps for vac stuff, redoing my coolant lines etc. do you have a pic of the exact lines you need to do
OK,
See the T fitting on the Driver Side. That is suppose to be recirculated back into the intake. My intake is a pipe with a maf adapter. I really don't want to drill a hole and tap the pipe, but in the past, I've seen fittings that were designed to pierce through couplers. This would serve my purpose perfectly.
