where to get tach signal?
TD or Not TD
Car: 1986 Corolla GTS
Since the CA is in my corolla, the tach is not working. so i have a 5''Autometer monster tachometer that i am going to have to use, do i run it to the wire that you hook up a timing light to? or is there somewhere else?
Also is there any setting on the tach that i need to change?
Nunook
there is a tach wire that comes off the ecu. i forget what pin it is, but u should be able to run it off of that.
TD or Not TD
anybody know the specific pin?
float_6969
Not to be an jerk, but I think I've told you that there is a link to the FSM in the stickies at least twice.
That information is READILY available in the FSM. Please do some work for yourself.
http://www.nicoclub.com/FSM/misc/CA18DE.zip
TD or Not TD
the FSM tells you what you need to set an autometer tach to for different vehicles? cool ill have to take a look.
float_6969
No the FSM tells you where the tach wire comes out of the ecu and goes to the stock cluster.
Your directions for your gauge, or the autometer website will tell you how to set up your gauge.
TD or Not TD
well the autometer website it down so i cant look there and i am pretty sure it is vehicle specific what you set it to. i found out that the tach in my LS2 powered 71 vega GT needs the tach to be set to a 4cyl signal. so i figured some guys might know here.
float_6969
That's a-typical. Set it up for a 4cyl and you should be fine.
As far as how to do that, IDK. Are the dipswitches not labeled?
TD or Not TD
i dont see any switches on it. i have tried taking the back cover off a while ago with no luck actually getting it off. im going to check it out tonight. i think my brother told me there is 2 wires in it that you have to cut. one for 6cyl and the other for 4cyl but i dont know how much i beleive that.
float_6969
Hmmm, that sounds odd. I've wired up a few different tachs (none of them were autometer) and they all had a switch/switches/knob you set to control how many cylinders it needed to look for.
kapower06
The autometers haves two little wire loops in the back, you dont have to remover any covers. I believe you cut both of them. but im not positive.
TD or Not TD
what KA power said is what i was told. but ill have to check autometer's website, it must be up by now.
float_6969
You cut both loops for 4 cyl.
