Where to get Tach signal
float_6969
To those of you running standalone, in particular SDS, where did you get your tach signal from for the dyno? When I tried to use the wire that feeds the tach, it was all jumpy.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
float_6969 wrote:To those of you running standalone, in particular SDS, where did you get your tach signal from for the dyno? When I tried to use the wire that feeds the tach, it was all jumpy.
Umm.... doesn't the SDS use regular spark plug wires? If so, it clips onto the wire for cyl #1.
float_6969
We tried that. It worked OK, but not awesome.
I DID find out, that if the magnets are dirty, it causes a "dirty" ignition signal. I posted that before I went back later today and tried it again after just wiping the magnets off with a rag. I'm guessing they had some metal shavings on them or something. I'm going to actually put it up on the dyno next week and see how it does with load on it.
