where to get RB25 A/C hose fittings?????
Jo240sx
Car: 1998 Nissan 240sx
i was wondering if anyone new where i could get some a/c hose fittings for my RB25DET...... I went to an a/c shop the other day and he was chargin 300 just to make em....
300Plus
Car: 1995 S14 w/ Rb25det Series II
hell I'll sell you the extras ones I have for 250 then lol
no but you should try to find someone that just got a clip and isn't going to run A/C. might be able to find another nissan with the same ends?!?
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
I have my complete AC system for sale bought an R33 clip.S1-RB25 I'll sell you anything you want from it.
zilvia14
Car: 240sx s14
l0nestar wrote:I have my complete AC system for sale bought an R33 clip.S1-RB25 I'll sell you anything you want from it.
If Jo240sx doesn't want it. would you sell me the A/C line only or with the compressor if you not willing to sell just the line. How much are you asking for shipped to 11378. My email is [email protected] , Have cash in hand. Thanks
Jo240sx
How much you wanna sell the compressor and fittings for??? my compressor was left open for 2 month so i dont kno if it still work but ill get it anyway....let me kno ASAP..... ship to 32951.... i cant stand this Florida weather without A/C...lol email me [email protected]
l0nestar
2004 Toyota Altezza
zilvia14 / Jo240sx,
I will get everything ready and list what all I have (again, I removed the entire AC system from my clip) I will try for tonight (whatever my schedule permits).
I will list out each item that I have, but I am wanting to sell most, if not all of it, you know? I know shipping on the compressor is going to suck But I have a _perfect_ shipping container for it!
Do you guys need the brace that holds the compressor to the block (it also has an idler pulley on it)?
Condenser coil?
I know that I have the lines and all of the bolts / nuts are already packaged in sealed baggies and LABELED!
Again, I have the whole setup, including the HVAC unit from the dash and the little sensor from the dash as well.
Jo240sx
l0nestar wrote:zilvia14 / Jo240sx,
Condenser coil?
I just need the compresser (what belt spins) and the fittings all the way to where the hoses end. That should do the job
kouki-gymkhana
Car: 1993 Nissan 240SX (only 90,000 mi!)
My motorset came with the RB25 compressor but no fittings for the compressor. I spent awhile trying to source them but no importer would let me have them for a reasonable price. I ended up just using an RB26 compressor and fittings and welded them onto my existing A/C hardlines. Cost me like 80 bucks or so. I would never have done my RB swap if it meant I wouldn't have A/C. You can't live in FL without it. Be warned though, running A/C on the RB25 makes it run SUPER hot (like H20 temps in the 90s C)
Jo240sx
kouki-gymkhana wrote:My motorset came with the RB25 compressor but no fittings for the compressor. I spent awhile trying to source them but no importer would let me have them for a reasonable price. I ended up just using an RB26 compressor and fittings and welded them onto my existing A/C hardlines. Cost me like 80 bucks or so. I would never have done my RB swap if it meant I wouldn't have A/C. You can't live in FL without it. Be warned though, running A/C on the RB25 makes it run SUPER hot (like H20 temps in the 90s C)
What kind of fans are u runnin??? I have 2 14" Zirgo fans and i had to put a nismo lower temp sensor because i was overheating when sittin in traffic for 20min....... with that lower temp sensor it hasnt happened since.... hopefully havin A/C doesnt f*** me over....
l0nestar
2004 Toyota Altezza
Joey,
Do you have the bracket that the compressor mounts to? The compressor does not bolt directly to the block. I'm just wanting to make sure you have this.
l0nestar
Jo240sx
yea i got it......
l0nestar
2004 Toyota Altezza
Joey,
Cool.
Modified by l0nestar at 10:50 AM 9/28/2007
300Plus
Having the condenser in front of the Radiator takes alot of air movement away from the Rad. I used a full bottle of water wetter and still had issues with it getting a little warmer then I liked, but it was only on days where it was 109 degrees out and 100% humidity. If possible I would suggest running one pusher fan on the AC compressor and one puller on the rad. I'm planning on doing this soon. but really with normal air temps around 95 I had no over heating issues at all and my fans are on a 185 degree switch
kouki-gymkhana
I'm running FAL 210s (12in x 2) mounted as pullers, a pignose A/C fan as a pusher, Nismo thermostat, a bottle of water wetter and 50/50 coolant, Koyo rad, bumper holes and underbody ducting. I have a 3in thick FMIC though and I know that it really hurts airflow through the rad. Combine that with a hot A/C condenser and the rad just doesn't get enough air to do its job. I have plans to swap out my bumper for one that has better airflow properties but I'm too broke right now to do it.
I'm seeing temps from 75-82C without the A/C, 85-95 with the A/C, spiking to almost 100C when I come to a quick stop after driving with the A/C on for a while. My fans bring it down somewhat quickly though.
Jo240sx
Im still lookin for those a/c condenser fittings...... hit me up [email protected]
