Where to get poly sway bar bushings
dtom4
ok-so I think the clunking noise I'm getting on my 07 SE is a sway bar bushing or end link issue. I'm going to replace both but would like to replace the bushings with poly ones, maybe from Energy Suspensions. Can't seem to find a vender for it or anyone listing poly bushings specifically for a 97 Pathfinder. Can anyone lead me in the right direction? TIA
Dave97 Pathfinder SEnewly acquired only 40K (miles not dollars)
max_stryker
Car: 1997 Nissan Pathfinder
proof read the post much? 07 or 97? LOL You can try and check Automotive Customizers at http://www.4x4parts.com and search the products column on the left hand side of te page. If AC doesnt carry them you can easily get oem replacement from the dealer OR you can head over to the local auto parts store and pick up some generic universal sway bar links. Good luck.
Also, the noise you described sounds more like CV joint issue, instead of a sway bar link bushing issue IF its coming from the front. If its coming from the rear - maybe the Rear Link bushings on the 4 trailing arms
