where to get parts for t28?
coreylol
i just bought a used t28 for my sr. and when i tried to swap over the oil outlet pipe i realized its a diff size. i guess my t25 is pretty old. im not sure...but the outlet pipe is too big to fit the new t28.
anyone know where i can get a new outlet pipe?
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
You need the S15 oil drain, and you can get one from frsport.com.
nzmoman
Car: 240sx 2 of em' and always lookin for more
I think you need different lines too if you don't have them already.
boro drift
nzmoman wrote:I think you need different lines too if you don't have them already.
Yes, you're right. Most importantly the oil line with restriction fitting. Also gonna need the adapter plates for the inlet and outlet pipes to.
coreylol
oil line restriction?? so none of my old lines will work?
boro drift wrote:Yes, you're right. Most importantly the oil line with restriction fitting. Also gonna need the adapter plates for the inlet and outlet pipes to.
Modified by coreylol at 1:08 PM 10/17/2008
nzmoman
try them, I dont think they work,
somebody makes a kit...
maybe FRsport...I can't remember. but the lines are not the same. and you definitely need the restriction on the oil.
boro drift
nzmoman wrote:somebody makes a kit...
Circuit Sports makes the oil and water line kit, and FRsport sells them. It's what I used on my car and it's a very nice kit. Braided lines and AN fittings.
coreylol
well the steel braided line that was on my t25 works fine...and my stock water fittings look like they fit. the bolt is the same size....so we'll see. the only thing thats different is the oil drain tube.
